Show only
Search instead for
Когда завезут новый UI, у большинства продуктов сносный UI имеется, об 3Ds Max же глаза ломаются. Хоть такой завозите, на коленке за 1,5 часа накидал) Готов бесплатно поработать
yup way better. One note though : the highlight color around the icons should use the traditional blue as it now in 3ds max or a tad different blue instead of a washed out version of the same green teal colour.
Also can you include in the concept also a viewport screenshot displaying geometry that uses as selection highlights traditional max teal color as suggested here on my idea. I think these two ideas go hand in hand:
It seems to me as another waste of time. Max's contains too many limitations of UI (wrong order Tab switching, storing windows position and size etc.) So, it needs to be fixed. But cosmetic improvements as this suggested doesn't makes work with Max better. So... -1
well if they are up with this Qt transition they better do it in the process because I doubt after anyone will touch the UI style
@brainpullwolf do you think you can add a viewport image where geometry uses the traditional Max turquise for Selection highlight instead of the outdated legacy red 😁
