Make the Max UI easily updated and/or returned to previous versions
  • Create a visual GUI to facilitate an easier icon replacement process so users can quickly update icons in 3ds Max on a large scale.
  • Design a method to allow the changed icons to be packaged and easily distributed.  (Possibly as a .mzp or .zip)
  • Create packages for all icons moving forward so that users can load the icons for any version of Max after this tool/functionality was created.
5 Comments
Kelly_Michels
brentscannell
Question for the OP and idea voters: Are you using custom icons or reusing icons from previous versions of 3ds Max?
brentscannell
Relaunching the question above: Are you using custom icons or reusing icons from previous versions of 3ds Max? This idea has a lot of votes, but very little discussion.
kris
The icons available on the forum still work, for the most part, so there's a sort of solution.  But it should be out of the box, and part of any subsequent UI redesign.  Eventually, the icons that exist won't be adequate as resolutions continue to increase...
Kris.
5thSth
autodesk wont get any new users because of new icons but might loose some... and if forced to learn new things... people would rather learn new software like Blender, than learn something they already knew.
