Helpful naming of copied maps and dropped bitmaps in SME
I suggest the following:
1. When copying maps and materials, it should behave more similarly to when copying objects. That it doesn't resat all naming to map #1927813674263, but instead has the same name or appends a 01, 02 etc.
So shift-dragging a map named "BaseCol Mix" would be copied as "BaseCol Mix 01".
2. When drag-n-dropping bitmaps on SME, it should name the map the filename of the bitmap. So instead of "Map #8945734589734589" it gets named "Wood_Normal.png" for example.
Quality of life, 4 lyfe! Please make it happen! 😄
3 Comments
tzaar
Also having the node automatically expand horisontally to show the entire name would be nice.
dswahn
This can be scripted so the possibility is already there. However, I strongly agree that this type of functionality should be made native so that users don't need to rely on third-party solutions. It would make life easier in Slate.
msanityTBG
@dswahn That "Slate Node Management" tool looks amazing! Is that something you developed yourself or that you found online?
Would you be willing to share a download link?
I spend a lot of time wrangling nodes in the SME and I'm starting to write my own scripts, but nothing as nice as that.
