Objective: When we are launching the manual help from Max program, manual help should be prioritized. Main topics should be easily searched without dealing with lots of noise.
The best case scenario for help in Max is the context sensitive help given in the Ribbon tools, that is excellent. The rest of menus in Max don’t have that privilege and only a short name appears.. The Ribbon suggests using F1 to get more help and I guess the same can be done in any item. But once used we are presented with a non context sensitive manual. Sending us directly to the manual page when hovering the item, appearing the hint and F1 would be ideal solution. Anyway we have a search function and it is there where our problems start.
Examples:
The search for Swift Loop:
The search for baking normal maps
The search for cut tool
Etc
Now we instead download the 3ds Max offline help, that is not connected to Max and needs to be downloaded manually, for the people that knows even exist. Is better? Perhaps, but won't solve fully our problems.
For those looking for script documentation the entries are so mixed with others that the best option is simply to download the CHM help file that will restrict the help only to his content. The old help of long time ago works better than the modern online version.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
