Name preview
Name preview
naming previews '_scene.avi' is just non-sense... previews have to be named with the scene name!
11 Comments
Kelly_Michels
nuno_moser
To be able to set a string to make the render file name automatic.
for instance:
Image_$camera_$frame.tga it would result in Image_CameraA_001.tga
Tags (1)
RGhost77
Would be nice have a token naming system not only in render output.
I vote for this.
nuno_moser
@RGhost77
I agree with you!
It could also be used to load things in to max such as textures, proxies, etc...
I vote for this too
viniciuspaciello
I was about to make a thread about this. Good!
sam_large
Hell yes to this. Especially if you could add a date field so that max creates a new folder based on the date you sent the render. (Something that could be turned on and off).
RPManager has had this for years but is buggy from time to time.
MartinBeh
Ideally, we would have a token-based naming scheme for previews, that includes a custom path where to store them. It's rather tedious to always have to 'rename' any preview that needs to be kept.
RGhost77
@MartinBehYou right, token would be better. I think MAX really need token system and it should works everywhere where filename is given.
gandhics
wrong item sorry
