The indicated parameter "Lighting Mode". Please open this up to script manipulation as at my company we are in dire need of it for efficiency. Also it would be helpful for this parameter and the "Keep Tris on Export" parameter to change multiple object properties at once. Currently we have to select each object that needs export individually and set both of these parameters. Yes "Keep Tris on Export" is accessible via script, but it would be VERY helpful if "Lighting Mode" was as well. It would be great to just select all objects needed for export and click a button! Thank you.
