Xref Scene filter in layer/object explorers
tbusseyA33GU
Observer Observer
tbusseyA33GU
Observer
Observer
Is there any way to filter out xref scene objects from the layer/object explorers?
They don't seem to respect the xref filter (I'm assuming this only works on xref objects, not xref scenes)
A娘
add a custom filter property when needed
global xrefobjectsel=#()
global AEI_objlayer_sel_delay = timestamp()
fn travelnode o =
	tempsel= for oo in o.children collect oo
	for oo in o.children do
		if oo.children.count > 0 do
			join tempsel (travelnode oo)
	tempsel
fn refreshxref =
	xrefobjectsel=#()
	count=xrefs.getXRefFileCount()
	if count == 0 then
	 	return 0
	else
		for i = 1 to count do
			aXref=xrefs.getXRefFile i
			xrefsel = for o in aXref.tree.children collect o
			for o in xrefsel where o.children.count > 0 do
				join xrefsel (travelnode o)
			append xrefobjectsel xrefsel
fn getxrefindex theNode =
	if timestamp() - AEI_objlayer_sel_delay > 5000 do
		refreshxref()
	if xrefobjectsel.count == 0 then
		return 0
	else
	for i = 1 to xrefobjectsel.count do
		if finditem xrefobjectsel[i] thenode do
			return i
	0
SceneExplorerManager.addReadOnlyProperty "xrefindex" getxrefindex
run script above , there will be a new filter called xrefindex added to list , active advanced filter and add rule xrefindex with 0 , xref scene objects will be removed , rule with 1 , only objects in 1st xref file shows
when add xref scene , layer explorer should be closed or not add xrefindex column or rule
haifeng_yuSEVKN
hello @tbusseyA33GU, thanks very much for the information. I noticed that it seems like we are not able to filter out Xref scene objects from the layer/object explorers. However, we can load/unload the objects in Xref Scene editor. May I ask how you would like to fiter out the Xref objects in the explorers? Are you trying to hide/unhide objects or move them to certain layers? Thank you!
Haifeng Yu
Technical Support Specialist
joaquim.moral
Hi @tbusseyA33GU,
Could you kindly confirm that you followed our colleague @haifeng_yuSEVKN's instructions? That way, we could help you more effectively.
Thanks!
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager
haifeng_yuSEVKN
hell @tbusseyA33GU, thank you for posting the question about Xref Scene filter in layer/object explorers. I assume that you may need a bit of time to work on this issue, please feel free to find if the information provided is beneficial to you. Also, you could try using the suggestion provided by @A娘. Thank you @A娘 for sharing additional information.
Haifeng Yu
