XRef cache
XRef cache
Message 1 of 1
XRef cache
I'm working with a file with several Xref objects and this is what I did:
1. Change one of the Xref objects in another computer (computer 2).
2. Update the paths in the main max file to solve the xref object (in computer 2).
3. I copied to the computer 1 the xref object (.max) and the main max file and overwrite them (they keep the same name).
When I open the main max file, an error arise about missing xref of old objects in the old xref (don't forget the main max file was updated and fixed in computer 1).
Does 3DS Max create some kind of cache files that could keep some old information if I open a file with the same name? I also work with CATIA and it is very usual to have this kind of problems since CATIA creates cache files in temp folders. The solution is to delete the cache files usually.
Replies (0)
