workspace (2025) dont work properly
Fab_Proto
Fab_Proto
Hi all
for me workspaces wont work.
I change windows layout, dock (or not) the scene exporer or the slate editor, save different workspace names
and when I switch workspace nothing is right (wrong windows layout, a 2nd scene explorer poping, slate editor undocked,...
Is there a problem with workspace management in 2025 version?
(Max 2025)
1. Reset the UI: Sometimes starting fresh can help. You can reset the UI by going to the Customize menu and selecting "Reset UI.
2. Update Software: Ensure that you're running the latest updates for 3ds Max 2025, as there may have been patches or fixes related to workspace management.
3. Check Preferences: Go into the Preferences and see if there’s anything related to workspace saving or UI management that might need adjustment.
4.User Config Files: Sometimes, corrupt user configuration files can cause issues. You could try renaming or deleting the user configuration files and allowing 3ds Max to regenerate them.
5. Single Monitor Setup: If you're using multiple monitors, try switching to a single monitor setup to see if that resolves the issues. Multi-monitor setups can sometimes lead to unpredictable behavior with saved layouts.
Enjoy your work.
