What is this?
What is this?
What is this?
This constantly pops up when i hide, unhide, freeze, copy, instance and when i use the right-click menu. I've never seen this in my life.
I re-installed Max because it never opened when i tried to. This has popped up ever since
Daf
There appears to be an issue with the Forest Pack plugin - specifically the Select Custom Object. You might try reinstalling it or posting over at the IToo forums.
I did find this post that may be similar to your issue
https://forum.itoosoft.com/forest-pro-(*)/i-get-this-script-error-when-i-right-click-the-mouse-why/
Here's the whole search - may be more info
https://www.google.com/search?&q=forest+pack+maxscript+error+type+error
Good luck!
Daf
3DS Max 2020.3
i7-4790 @4GHz • 32GB • GTX 1080/8GB • Windows 7 Pro
I've located and fixed the problem. Turns out the usermacros in a hidden folder were causing it.
1. https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-enable-hidden-fil...
2. https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
Turns out some of my folders were hidden. Thanks for the info!
