After months of experience with different file formats, I would like to start threads in several forums about two interesting ones: OBJ and FBX. I believe they are getting a bad rap, are underutilized, misunderstood and it is our own fault.
For starters, having downloaded dozens of models I arrived to this erroneous conclusion:
OBJ and FBX are for clay, geometry only models.
Then I found a few colorful ones, so I revised my long held belief:
OBJ and FBX can carry colors but not Textures.
[To be continued]
-Ramon
Solved by raymond98P45. Go to Solution.
Probably most folks know that the *.mtl (material) files are text files. You may change their extension to filename.mtl.txt and see their innards with Notepad.
At this point it is pertinent to take a look at this post:
This is how you find out what textures/maps are known by a file
If you use a Windows 10 computer, you may double click on any *.fbx or *.obj file. Most of the time the built-in Windows 3D Viewer will display the object and allow the typical manipulations.
-Ramon
A partial answer may be found here:
How come my object won’t export its texture maps?
-Ramon
JFK Numbers
