Is it possible to setup up volume lighting using the photometric lights so that Max can render using the ART engine? even though I can add the effect and pick a light, my scene doesn't change. not sure if I'm missing some setting or if this isn't supported.
I used to use Mental Ray (which has now been removed and the plugin from NVIDIA isn't on their site that I can see. Also I don'twant to use Scanline rendering.
Solved by kgokhangurbuz. Go to Solution.
Hi;
Volume Lighting nor Volume Fog (atmospheric or gizmo-bound) are not possible in ART Renderer as far as i know.
Regards;
Hello @MJustinTaylor,
@kgokhangurbuz is correct that this is unsupported. The idea behind ART was to leave behind all the advanced 3D features so that the renderer is easy to use for people who just want to get some basic lighting in. For more advanced things like Render Elements, Volume lights, and Volume fog, Arnold, Mental Ray, Vray, etc would be required. (If Scanline isn't an option.)
Mental ray still exists, NVIDIA will be putting out a 2018 version soon enough. Other plugin makers also don't have their 2018 versions out yet, but there is no doubt that NVIDIA will have a current offering. I have more information here. It doesn't ship with Max anymore but it's still going to be available. Please let me know if you have any questions.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
I just wanted to follow up here, any questions about MR or anything? I just wanted to be sure you got the answers you were seeking. Since @kgokhangurbuz is correct about ART not supporting volume light, I will mark his post as the solution but please feel free to keep posting in here and I'll do what I can to answer your questions.
Best Regards,
