Viewport Rendering Issue
I'm having an issue with 3ds max not properly rendering the viewport and causing weird jagged dark patterns. I'm not sure if it's the scale of the model i'm working with, I'm currently blocking out the scene so there aren't many polys, or if it's a problem with 3ds. This started today with this scene and I don't think it happened previously in the past few weeks or I'm sure I would have made a post then. This is not a huge deal but it is a bit of an annoyance when trying to view objects at certain angles to match scale.
As I continue to work it seems like this issue only happens when I'm using perspective view. I can use orthographic, I found this out because 3ds forces users to orthographic sometimes, and everything looks perfectly fine.
