When you enlarge the windows, the frenzy happens as in the video.
Problem?
Graphic card Nvidia gtx 650Ti
Version Driver 381.89
Solved by Alfred.DeFlaminis. Go to Solution.
Hello @BASSIT,
On a technical level your card isn't on the certified list for 3ds Max 2017. The 2018 list isn't updated yet but overall it'll be similar to the 2017 list. Because of this, you may experience viewport problems like the one shown in your video. My best suggestion here as a workaround would be to find the least distracting display driver in 3ds Max and use that. Is that an option for you? Otherwise, you may need to update your graphics device.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @BASSIT,
I just wanted to follow up here, any thoughts on my previous post?
Best Regards,
