I have more than 250 files that are distorted when loaded into 3Ds Max 2022. I have been attempting to approach different solutions to this problem, however I did not encounter one solution on Google. The files I am opening are saved from 3Ds Max 2019 and 2018. However, even upon downloading the 2020 version, the models are still distorted.
Every file has an Edit poly modifier that is causing the issue. I have seen a way to solve the distortion problem where I collapse the modifier stack and convert it into an editable mesh without the edit poly affecting it. This is an effective technique, however I am in a situation where it is irreversible. The edit poly modifiers in every model is permanently distorted. In fact, upon opening a large 2019 file, 3Ds Max 2022 crashes. I will provide visual proof of some of the files below:
Above is an image of a model that was opened in 3Ds Max 2022 from being saved in the 2019 format. The model to the left, fortunately, has been collapsed to an editable mesh in a later file, so I have the ability to compare it to the model on the right. The model on the right is the distorted version, which has an edit poly modifier.
The image above is a closer view of the comparison (the bottom is distorted while the top is untouched).
This was a work-in-progress file. Again, this is in the 2019 format opened in 2022 and 2020. The mouth at the bottom is entirely distorted.
This is supposed to be a spherical shape, but from the rear the vertices distort.
With all of these models, when I select all of the vertices under the edit poly modifier, all of the coordinates (x, y, and z) show 100000000000. However, when I move the vertices with the Move tool the slightest bit (the gizmo does not show up, I moved the vertices with the mouse), the model completely disappears out of the scene and shows this in the coordinate system:
Upon seeing this issue, I would like to chronologically list what happened before these problems began to arise. The information below might be completely unrelated to the problem, but I felt it was important:
- I deleted 3Ds Max 2019 entirely from my computer to download 2022. The files turned into blank icons.
- I downloaded 3Ds Max 2022. Model distortion began when opening 2019/2018 files.
- When I save a file from 2022 to any older version, I get a message about "PolyOperations" not being supported in previous versions other than 2022.
I hope there is a possible explanation to why my models are distorted. I've invested in thousands of hours working on these files. I would be glad to make these models work correctly again. Thank you!
Sincerely,
Lauryn
