UVW Unwrapping, polygon outside of the area.
Hi, got a problem with UVW Unwrapping. I've extract a model from a videogame, then i try to change textures. But when i want to UVW Unwrap on the arms, one polygon is totally outside of the arm area. Please check the following screenshot to understand : http://prntscr.com/eetk5c Is-there any solutions to make the polygon joining the whole arm part to texture it well? Thanks you.
Replies (14)
blakestone
You can use 'Stitch Selected' or 'Target Weld' to complete this task.
Using 'Stitch Selected' you select the edge you want the connecting edge to join and then select : Tools > Stitch Selected (see attachment).
You can also assign a hotkey for this so that you do not have to keep repeating these steps for lots of stitching.
Technical 3D Graphic Artist
Autodesk 3dsMax 2015 - Service Pack 4
Hey, thanks for your quick answer.
This seems to be the great solution, but when i select the two edges i want to join, and then press Stitch Selected>OK, litteraly nothing happens, it just unselects both edges.
Do you have any idea about this problem?
Leo
blakestone
Stitch Selected only seems to work when a 'single' edge is selected.
So select a single edge and select 'Stitch Selected' and the connected edge should become stitched.
Note: A valid edge which can be stitched will be 'Green' - so only select the 'Green' edges for stitching.
Hey, thanks again for the reply.
But same issue there, i've tried with the both edges i want to join as you can see on theses screenshots :
http://prntscr.com/ef0kqm
http://prntscr.com/ef0kxj
but still nothing happens, and both edges are green.
any ideas?
many thanks,
Leo
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I'd like to help here.  If stitch is giving you problems, you can also use the Target Weld function in the Tools menu of the Unwrap window.  It might be easier for this issue.  With Target Weld, it's a bit different than how that tool works on an Edit Poly.  In the Unwrap window, you have to click on the vert to be moved and welded, hold the mouse button down, then drag it to the vert you want to weld to and let go.  If you select the vert before hand, it will change the color of the vert where it should be welded to.  (Blue.)  Can you please try that for me?
Best Regards,
2 things pop out for me..
01) why is ALL your arm lit up in red ? is that wirecolor...if it is, I would suggest you change it cos it's a hinderance to most things
02) when you select an edge in the UV editor...the corresponding edge that it 'should' be welded to should be blue...I don't see that in either of your pic meaning...they aren't geometrically welded.
Collaspe the Unwrap to save your progress up to this stage, go back to your editable level, make sure the verts at that Triangle are properly welded..
Now do another unwrap and see what happens
(if you don't properly weld your geometry, doesn't matter which method in unwrap, whether be verts/edges....you can try til kingdom come and it won't weld)
(need I remind ppl to regularly use the Tools>Channel Info to check for dead verts ?)
Aha...just as I thought, I re-read your post at the top and it says 'polygon outside the area'.......well theeeeeeere's your problem....gotta geometrically weld it first...carry on.
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
@Anonymous, in post #3, you replied saying it DIDN'T work...now you accept it as a solution...
What the ????
Alfred.DeFlaminis
Hello @Anonymous,
I'm the one that marked it.  The OP mentioned that stitching didn't work but I'm confident that target welding would work.  I expanded on it a bit in my post, but @blakestone suggested it first so I marked his post because I know it would work.  However if @Anonymous told me it didn't work I would unmark it and then make a video walking through it, get confirmation and mark it again.
Best Regards,
ok, apologies to @Anonymous, wasn't you
right, as i suggested, you have to weld the floating triangle to the arm first in Editable Poly, if you don't, goodluck trying to weld the UVs together using ANY method...it is impossible
here...if you leave the two elements unconnected like this...prove to me you can weld them together in UV...FloatingPanel.jpg
Alfred.DeFlaminis
Hello @Anonymous,
Actually this is a very good point by @Anonymous.  If those aren't welded on the geo level the uv's will not weld.  I hadn't considered that but it's a great point, kudos.
Best Regards,
now @Alfred.DeFlaminis you party pooper...I just want to torture people a bit...let them try and try and try.......and try...and try...
Alfred.DeFlaminis
I gotta admit @Anonymous, your sense of humor is growing on me.
On a serious note, if I had missed a mention that the polys weren't welded that's my bad.  That's a very good point, party pooper or not.  Smiley Very Happy
Best Regards,
well considering all the 'stuff' you have to go thru...being on the frontline taking all the heat from disgruntled customers....you're forgiven !!!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
