I'm not a 3DSM expert; in fact I use it so infrequently consider me to be a newbie.
I do know Inventor very well and therefore might use the incorrect terminology.
I've had to simplify this explanation as the whole process has lasted since this time last year and I can't remember all the details in chronological order.
I've used Pro-Boolean and Pro-Cutter on 3DSM generated solids/bodies successfully.
However, I'm having a lot of problems getting it to respond the same way, the correct way, as it was designed to respond when applying them to imported bodies.
Primarily, I find that BOTH bodies (operands) disappear.
I've tried a little experiment using the attached files. I've had problems with Pro-Boolean when applied to; Bodies, Editable Meshes, Editable Polys. Both operands will disappear!
When I tried with Pro-Cutter I could only get it to work properly on Editable Polys, it wouldn't work on the imported bodies or editable meshes.
My workflow, I imported these files, tried Pro-Boolean and Pro-Cutter. No joy.
Then, I imported these files, Converted to Editable Mesh, still no joy.
Finally, I imported these files and Converted to Editable Poly, no joy from Pro-Boolean, but I did get success from Pro-Cutter.
As I thought I'd found a solution to my problem, I then tried Pro-Cutter on 2 Bodies I had previously imported from Inventor (IAM & IPT files). I can't upload these latter files.
Again, both components disappear, but one remains in browser on left.
I was expecting that the Stock object or first selected object in Pro-Boolean would remain, the cutting object would disappear from both the graphical area and the browser on the left.
Either, I'm doing something wrong or 3D Studio Max isn’t responding the way it would with native objects.
HELP, please.
