Turbo smooth weird shading problem
Message 1 of 15
Hi.
I've run into this weird problem when applying turbo smooth. I created a simple box , applied a chamfer modifier and then applied turbo smooth on top. As you can see some of the edges have become black and this shading issue is also visible when rendered. Any idea why is this happening?
Replies (14)
Message 2 of 15
miledrizk
This is a smoothing groups problem, the chamfered faces are not blended well with the adjacent
Faces, so you need to enable the option "Smooth Chamfer Only" and, at the same time check
The option "Smooth To Adjacent".
[email protected]
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
Message 3 of 15
I've followed your instructions and Im still getting the same result somehow...
Message 4 of 15
Here's what happens when chamfer amount is set to 20 :
Message 5 of 15
And here's a box with only turbo smooth on top. Im pretty sure it's got either something to do with turbo smooth or 3ds max itself... maybe a glitch?
Message 6 of 15
miledrizk
I'm sending a Max file with the box I made so you can compare the parameters:
https://drive.google.com/file/d/1KyQrrxmVwmo5Gr1H4B1KwOv6h5pVz7kt/view?usp=sharing
Now for the last image without the Chamfer, it's normal what you see,
If you orbit the scene you'll see the dark shading will shift based on the view angle,
This is related to the Vertex Normals orientations. Try adding an Edit Normal modifier
So you can visualize the Normals.
[email protected]
Message 7 of 15
Im using 3ds max 2017 so I couldnt open your file.
as for edit normals, here's what I got :
Message 8 of 15
miledrizk
This is the 2017 version, maybe you'll notice something in the parameters:
https://drive.google.com/file/d/1811E2IP0zOzhGpytJR8WqxCzB-CM5kXK/view?usp=sharing
[email protected]
Message 9 of 15
I think there's something wrong with my 3ds max. Is there anything I can do to fix this?
Message 10 of 15
miledrizk
I managed to reproduce this by adding an Edit Poly modifier,
But in your case, if this is what you're getting without adding anything, it's hard
To tell what's going on. It's a Normals orientation issue, but I never had the 2017 version before,
So i guess you can look for updates maybe it can change something.
I can suggest resetting your User Settings if you like:
1- Close 3DS Max
2- go to: C:\Users\YourUserName\AppData\Local\Autodesk\3dsMax\20xx - xxbit
3- Rename the folder called ENU to something else like ENU.old
4- Restart 3DS Max
Note: AppData is a hidden folder, so you need to enable the visibility of hidden files and folders
From the Control Panel
Also, you'll lose any custom UI or any custom 3rd party macroscript you installed.
If renaming the ENU doesn't help, then close Max, delete the newly created ENU folder,
And then rename the old one ENU again, this way when you restart 3DS Max you'll get back
All your custom UI and Macsroscripts.
[email protected]
Message 11 of 15
I tried renaming the ENU folder. 3ds max got a reset but the turbo modifier issue is still there. super confused right now...
Message 12 of 15
miledrizk
Ok, start all over again with a new file and a new box,
But this time instead of TurboSmooth, try OpenSubdiv for smoothing.
[email protected]
Message 13 of 15
The problem is still there... i dont get it
Message 14 of 15
I think ive figured it out. it was a shading problem. when viewport is set to standard I get that display glitch, once it's set to Performance or other options the model is displayed correctly. weird.
Message 15 of 15
miledrizk
It's also a good idea to test your scene a real situation, I mean by placing lights and doing a render with
GI, since in the end, this is how things will be done.
Another thing, in TurboSmooth there is a parameter that can improve the Normals quality in
Display and Rendering, and that is "Explicit Normals", you can find it in the Main rollout.
Below are 2 screenshots for Before and After checking this option:
1- Before1- Before
2- After2- After
Note: Use this option if Turbosmooth is your last modifier in the stack, or, at least, you're not going to
Add any modifier that can change the topology of your object, like an Edit Mesh modifier or something like that.
[email protected]
