For background info, please see this post:
What is the deal with the OBJ and FBX file formats?
There are too many geometry/clay only OBJ+FBX models out there. Both file formats are treated like some sort of 2nd. class citizens. I have been investigating both but I prefer to focus on OBJ because I get to see the contents of its material file. Additionally, a folder gets created and the exported material files are placed there (when it works, that is).
These are some of the models under experimentation and the results:
Exportable:
Kitchen Sink is fully exported perfectly
Avocado is fully exported perfectly
Medieval House is fully exported perfectly
Luminaris Starship is fully exported perfectly
Chesterfield Couch is fully exported perfectly
Non-Exportable:
Vases Shiny CANNOT be fully exported to OBJ or FBX
Branches in Vases CANNOT be fully exported to OBJ or FBX
Pallet Bed CANNOT be fully exported to OBJ or FBX
Almost anything V-Ray fails.
Semi-Exportable:
Lamps for the Loft (colors only)
Bed Wood (colors only)
Modern House is deficiently exported
McLaren (V-Ray): FBX fine, OBJ poor
Solved by raymond98P45. Go to Solution.
If you want to make a Full Export to OBJ, make sure that you click on the following dialog:
If the export is successful:
(1) You will see filenames like .jpg, .png, etc. inside the *.mtl file generated.
(2) A folder named "maps" (your choice of name) will be created. The material files will be placed there.
TIA,
-Ramon
A case that shows the lack of consistent behavior by the 3ds Max export to OBJ function has been found.
These OBJ+MTL files were generated by my laptop:
These OBJ+MTL files were generated by my desktop:
As far as I can tell, both computers are equivalent. They are running the same OS (Windows 10) and the latest version of 3ds Max 2020. The MTL files are essentially identical.
The model in question may be downloaded from here:
-Ramon
It seems like the best way to know whether the Full Export worked is by noticing the dialog below:
These 2 succeeded:
This one failed:
-RFH
