i accidently deleted the button on my toolbar that is called "toggle ribbon". i'm not sure where to find that button, what tab and category it's listed under.
does anyone know?
Solved by vusta. Go to Solution.
Main UI -> Ribbon -> Show Ribbon
Though it will not have the icon, couldn't find a way to restore it, since the new icons are not listed in the "Edit Button Appearance..." menu.
it's there..just playing hard to get...just select Image Button (might have to switch back and forth between Text Button and Image Button for it to kick in), Change Group to Ribbon...then there should be just one icon....
Also change the Tooltip to Toggle Ribbon
thanks. my button is totally gone. i accidently removed it as i was removing some other buttons via right-click > delete button. i can't where it is in the right-click > customize.
Customise User Interface>Toolbars
hit s, scrolldown to Show Ribbon, drag it up into just left of the 'wavy' graph button...do the rest as per previous posts...
ha! sweet. thanks. i never thought of "show" - toggle, yes, haha but not show.
