texture not appearing
jpmarchetti
Message 1 of 1
jpmarchetti
Hi , i have a weird issue , i say weird because everything went fine until yesterday , when suddenly the problem appeared . i'm using Max 2014 with a script . i already tested that script on Max 2014 and even on 2013 and it worked perfectly . but since yesterday i have a problem . that script allows you to import/export stuff from Max to a game . that script has a map helper which is a plane surface splitted into nine jpg that allows you to show where to put your object or map into the game . but since yesterday the map helper (surface) texture(s) doesn't show up anymore . it shows a blank surface . and it's very annoying as you can't see where your object will be located in game . the guy that made the script is a good programmer but he couldn't find where the problem was , so i hope i'll have more luck here (hope i'm in the right category) . below i put a pic , the big map is my imported map , and the small white square in the middle is the script map helper (game map) . As you can see it doesn't show any texture
Replies (0)
