I am getting state sets errors whenever I try and open the rendering menu, even in a fresh, empty scene immediately after booting up. A popup box appears with the message:
Sytem.NullReferenceExeption: object reference not set to an instance of an object.
at Autodesk.Max.StateSets.ActionItems/OpenClose.get_IsChecked()
It also happens when I shut max down. I also get this error message when I boot up max:
Exception and Stack trace: System.TypeLoadException: Method 'Reinit' in type 'Autodesk.Max.Wrappers.HashTable' from assembly 'Autodesk.Max.Wrappers, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
Max also boots up very slowly despite being installed on my SSD system drive. This is after installing service packs 1-3 and rebooting my machine. Are these problems related? How do I fix the StateSets problem? Being unable to access the rendering menu makes completing my tasks pretty much impossible.
