I'm getting this error on 3ds max startup.
Nothing is broken but I want get rid of it, is it possible?
I have 4 3ds Max version installed: 2016, 2018, 2020 and 2021.2.
All of them except 2020 have TyFlow installed and all of them except 2020 have this error.
If I remove tyFlow.dlo from plugins then this error dissapear. If I install tyflow to 2020 then error appears.
I'm not sure if this is directly related to tyflow but correlation is obvious.
UPD.
Already documented http://docs.tyflow.com/faq/miscellaneous/
I did not start 3ds max 2021, due to finding this script in autorun , CoronaRenderer_InitScripts.ms, when it was deleted, then 3d max began to run properly
