Source file not found
I have an installation problem. It's :
"Source file not found : C:\Autodesk\WI\Autodesk 3ds Max 2016\x64\max\Autodesk\3ds Max 2016\adskassetapi_new-6_3.dll. Verify that the file exists and that you can access it."
 I search if that file exists, it exists but, I can't restart, I give up or ignore it?
Can you help me quickly please if it's possible?
Thanks.
miledrizk
Check this thread:
https://forums.autodesk.com/t5/installation-licensing/missing-dll-files-in-installation/td-p/6734647
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
It's fixed now. i've remaining files at hard disk. They are deleted and it's work.
"Source file not found : E:\3D\3ds Max2014/x64/Max/Autodesk/3ds Max\ 2014\Setup/MRF/en-US/example Desc.htm Verify that the file exists and that you can access it."
Can you help me  please, if it's possible?
Thanks.
jon.bell
I noticed that your installation path is on an "E:\" drive, which may be a mapped drive path (either on a network or an external drive.) If you change your drive configuration, that drive letter may no longer be available or may be assigned to a different letter, so the path will get broken.
Can you confirm that this path exists in a Windows Explorer menu? Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
