Some Edges Cannot be Selected
milanvidovic
milanvidovic
For some reason I've randomly run into this problem. I was just modeling using a plane. What's the issue here? You can see the region selection around an entire Edge. It refuses to select. Some edges on the object just refuse to select. Also look at what happens when I Ring then Connect that edge I can actually select. See how the Connect operation isn't planar with the edge in the corner that's at an angle? Odd.
darawork
Is what you're modelling close to the origin point 0,0,0? Also I'd be restarting Max when this sort of stuff happens. Sometimes when stuff that 'simply should work' doesn't, a quick restart usually solves it.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
domo.spaji
You trying to select (still) non existing edges - made by shell mod. upper in the stack.
darawork
Yeah, as above, collapse the stack and try again.
Darawork
AutoDesk User
milanvidovic
😂Yeah. That was it. A detail I missed.
