I just discovered that occasionally, the MMB refuses to work as expected especially inside the UV Editor. When I press the MMB, the little hand icon in the lower right corner blinks momentarily but does not stay ON and the pan function using the MMB doesn't work.
This was driving me insane for about an hour then I stumbled upon the fix.
Solution:
If you have a Logitech mouse, the Logitech Gaming Software (LCore.exe) occasionally has a spaz attack and screws up system wide with varying behaviors across different apps. In Max UVW Editor it does as described above and Pan stops working as well as any function using the MMB. To fix this, kill the Logitech Gaming Software or restart it and everything returns to normal.
I hope this spares others the frustration I went through when this happened to me.
Hello @Anonymous,
Thank you for posting this and being a proactive member of the community. There is a limitation of the forums where the original post cannot be marked as the solution. I wonder, would you be willing to reply in this thread with the same info and you or I can mark it as a solution? This way you get credit for your great addition to the community and people who search for this issue with 'solved threads' will find it more easily. Thank you very much for doing that!
EDIT: Spelling.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
As per request, this is the solution part of the initial post:
Solution:
Thank you very much for doing that @Anonymous and thank you for your contributions to the community. You are appreciated.
Best Regards,
