I am using a slice plane to remove the top half of two objects. I have tried using the same instanced slice plane as well as two unique slice plane modifiers. Both yield the same incorrect result. See attachment.
1. The slice plane (positioned at world 0,0,0 and rotated 0,0,0)
2. Object being sliced correctly
3. Object being sliced by same slice plane, incorrectly.
the top surface of 2 and 3 should be sliced at the same place so the top is completely flat and coincident with the slice plane. I also notice that if I "remove bottom" instead of "remove top", the part of 3 that sticks up is reversed, so the surface of 3 ends up below the surface of 2.
I need to take a very accurate measurement of these objects at this precise slice and this error is preventing me from doing it.
Your post subject line has been edited by @hagen.deloss: Slice Plane is Not Accurate
