Slate Material Editor copy paste maps?
wrreisen
wrreisen
Please could you give a clue how to copy paste maps in the Slate material editor. I would like to take a Color correct map with a certain set of values then copy paste it and use it in another material running another bitmap through it.
Thanks for any advice.
darawork
I've not seen copy and paste available.
You could hold shift and drag the element to copy an exact copy of it.
If it needs to go to a different tab just right-click it and -> move to tree...
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
wrreisen
Thanks perfect
actrask
But what if you want to move 25 materials to another tree? 'move to tree' only shows up with a single material selected
darawork
Maybe save selected to a new material library?
Darawork
AutoDesk User
