Message 1 of 10
06:01 AM
I am not a 3DS MAX user, however I am testing that for GPU performance measurements. I have a file and opened it in the 3DS MAX 2018. I went to the Modifier and then Plane. Then I changed the Length segs and Width segs (both are 100). Next, I went to Cloth and clicked on Simulate while the Progress has been checked.
Now, it seems that the job is running on CPU only. According to the GPU-Z application, the GPU load is 0 and all core and memory clocks are idle (lowest value). After 10 minutes, the frame progress is 26/100 which clearly states that GPU is off!
How can I force 3DS MAX to use GPU? The GPU is a Quadro M2000?
