3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Share your favorite tips, tricks, workflows, and secrets in 3ds Max.
237 REPLIES 237
Message 1 of 238
Alfred.DeFlaminis
49671 Views, 237 Replies
Hello Everyone!
I wanted to make a thread about sharing your favorite tips, tricks, or secrets found within 3ds Max.  From awesome hotkey combos to those really essential tools that everyone may not know about, this is the place to share!  I've started the ball rolling below with some really cool tidbits on the particle flow presets that people may not be aware of.
Please, share yours too!
Best Regards,
Tags (2)
237 REPLIES 237
Message 181 of 238
Swordslayer
Why so complicated?
macroscript DeselectAllSubObjects category:"Edit"
	local obj = modPanel.getCurrentObject()
	if isKindOf obj Editable_Poly do
		polyop.setVertSelection obj #{}
		polyop.setEdgeSelection obj #{}
		polyop.setFaceSelection obj #{}
		completeRedraw()
Anyway, to get back to the topic of tips and tricks, did you know that if you're in quad chamfer mode in editable poly, you can hold ALT while dragging right/left to increase/decrease segments count? Doesn't work with regular chamfer, though, because nobody touched the code in ages…
Message 182 of 238
in reply to: Swordslayer
Thx, i'm newb in maxscript, thats why)). Nice tip, used it in past.
Message 183 of 238
lukuanenko
Very nice trick with tape
How to align any object in the scene with Tape Helper
In Autodesk 3Ds Max, there are several ways to accurately align an object in a scene. I'll tell you about my method using Tape Helper without special plugins and scripts, and it's pretty fast.
https://3dground.net/article/how-to-align-any-object-in-the-scene-with-tape-helper
Message 184 of 238
Swordslayer
Message 185 of 238
More procedural modelling with Shaders!
Cloth and fabric creases....
Think sleeves, trouser legs, boots...
Message 186 of 238
Swordslayer
If you want to avoid the viewport jump when entering isolation mode, you can deactivate 'Zoom Extents on Isolate'. Note that unlike 'Zoom Extents on Import', this is a per-session setting so it will get reset to its default on value whenever you restart max. In case you wanted to avoid that, you can make a .ms file inside the scripts/startup folder of the ENU folder and put this line in it:
actionMan.executeAction 0 "262" -- Tools: Zoom Extents On Isolate toggle
Message 187 of 238
in reply to: melissa.lax
Very useful article, many thanks
Message 188 of 238
Hi
Today I was just messing around with max n I did a spine rig using an unorthodox method (perhaps a stupid one!)
What do you think guys?
Could it be a legit way to rig?
Message 189 of 238
If you create your own toolbar, and want to rearrange buttons locations, simply hold 'Alt' key in your keyboard and drag by left click to where you want it to be.
Tags (1)
Message 190 of 238
photodave
in reply to: Waseem_Dabbas
3ds Max 2020 Wont launch after reboot?
So I have been fighting for 3 days with 2 workstations and a third has shown up with the same problem and this time I figured out a fix.
1. Open windows services panel
2. find the service "Autodesk Desktop Licensing Service"
3. If the service is not running try to start it manually
4. If it starts the GREAT! you can stop here. If not then keep going to the next step.
5. If it wont start then open the file explorer and navigate to "C:\ProgramData\Autodesk\AdskLicensingService"
6. look for a file called "AdskLicensingService.data" and open it in Notepad
7. IF there is nothing in the file, close notepad and either delete it or if you are weary of that, just rename it to something like "AdskLicensingService.data.old"
8. Go back to the services window and try to start up the "Autodesk Desktop Licensing Service" again.
9. if it starts, it should create a new "AdskLicensingService.data" file in the folder from step 5.
10. If all that goes well, your 3ds max 2020 "should" fire right up.
I dont know it it is Autodesk or Microsoft but it has and still is a serious pain in my butt... Hope this will help others save time and reduce down time.
Message 191 of 238
in reply to: photodave
Topic is a lot of good tips, learning well from here!
Thanks!
Message 192 of 238
pyroskat
Vojtek.  Once you said you can apply an FFD to a camera, and I remember doing that once, but doesnt look working anymore? Or I just cant figure out how to do it.
Message 193 of 238
in reply to: pyroskat
I managed to distort my camera with an ffd modifer by moving the control points. I am curious as what you would do with it.
Message 194 of 238
I just assigned a path constraint to a camera and a circle
I then distorted the circle with a ffd modifier b  animating the control points. Turned out kind of a neat result.
Could that be what you are looking for?
Message 195 of 238
pyroskat
Oh yes, actually its working. Just not sure why was not working before.
One limitation (understandable) is that it only pinches the corner points of the camera, and not really deforming it.
I was looking for something similar to MeshWarp in AE, where you have a mesh  that you can deform.  So instead of just the 4 corners, I can select the middle part and squeeze this part in relation to the rest.
I want to only deform the 2d output not just the mesh itself.
Message 196 of 238
The way i would do that is create a plane with as many polys as you need then assign your map then use soft selection.
Message 197 of 238
Really fast method for detach objects by elements.
This method - 3 minutes
By scripts - 30 minutes
just enjoy
https://3dground.net/article/break-object-by-elements
Message 198 of 238
Hello Really fast method for detach objects by elements.
just enjoy
Tags (1)
Message 199 of 238
is the the result your are looking for? @pyroskat
Message 200 of 238
I see that the rotation gets sticky to an axis; that I first have to rotate the locked object along an axis (and then undo) before I can rotate along the desired axis around another object.
Technology Administrators
