server busy
server busy
Message 1 of 10
server busy
has anyone gotten this?
https://gyazo.com/67c7d2f21cdeaaf456163ca3b55e2858
I have been getting this a lot lately.
Replies (9)
Message 2 of 10
Alfred.DeFlaminis
Hello @Anonymous,
Is that happening when you start 3ds Max?  There is a minor issue for some people where the 3ds Max process is staying in memory.  There is a link here on how to fix it.  Thing is.. not sure what that has to do with Servers if it's the same issue.  Can you expand a bit on this?   Thanks!
Best Regards,
Message 3 of 10
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on your issue?
Best Regards,
Message 4 of 10
Good morning Alfred!
No still have the error
Mark Rogers
Industrial Designer & Sales Support
Automated Process Equipment
1201 North Fourth Ave.
Lake Odessa MI 48849
phone: (616) 374-1000 x 118
fax: (616) 374-1010
markr@apecusa.com
www.apecusa.com<>
[New Globe Logo and disc]
Message 5 of 10
Alfred.DeFlaminis
Hello @Anonymous,
Can you please expand on this a bit?  What are you doing when this happens?  Is it coming from Windows?  Is there a 3dsmax.exe process in memory when this error happens?   Should there be?
Just trying to get more information.  I wonder what the 'server' in this case is.  Thanks for any details.
Best Regards,
Message 6 of 10
Good morning Alfred
Yes I would be happy to expand on this. This error comes up every time I fire up Max. This is a stand alone max installation. I am on two servers. the main company server and my own server for backburner.  I never had this issue before. We did a server upgrade recently and I will check with I.T. this morning to see what exactly it was. Not sure but it may have started after that.
Maxi s the only program I get this  from.
Message 7 of 10
Alfred.DeFlaminis
Hello @Anonymous,
I wonder if the new server is somehow blocking WsCommCntr2.exe.  If you manually stop this process, do the problem persist?  The comm center is the only thing that will try to start before 3ds Max so it seems like it may be at the center of this problem.  (Or rather, it's inability to communicate outward.)  If you close that process and then start 3ds Max, does the problem go away?
There are ways to fully disable the comm center, but it has ramifications for 3ds Max usability.  Let's try killing the process first and see where that leads us.
Best Regards,
Message 8 of 10
Alfred.DeFlaminis
Hello @Anonymous,
Best Regards,
Message 9 of 10
Thanks Alfred
I did not need to kill the exe. I had our IT guy in last Thursday with other issues. I think i had some other issues. I had a bunch of files synchronizing for external use for some reason which I did not need at all. I fired up Max this morning and had no error. Thanks for you help as always
Message 10 of 10
Alfred.DeFlaminis
No problem @Anonymous, I'm glad it worked out!  That was a strange one but seems like it was just a one-off.  Have a great week!
Best Regards,
