Select by inside object?
remainz
Message 1 of 1
remainz
Is there a why, with or without maxscript, to select objects that are inside other objects? I need to remove and hide or delete hundreds of planes from inside the bodies of many renderable splines . I can of course convert the splines to mesh if it helps. So I cannot use the bounding box or global position as they are too impresice. thanks
Replies (0)
