Announcements
Script for 3ds Max to animate a group of objects - sequential movement
oprestonWK48B
Observer Observer
oprestonWK48B
Observer
Observer
Good day to all! Good luck and health!
Tell me pls. Is there a script / plugin for 3ds Max to solve such a problem in animation:
- there is a model consisting of a large number of separate objects.
- it is necessary to disassemble this model in this way: all objects, starting from the extreme one, move in turn along a certain axis at a certain distance from the model and remain there.
That is, the first object moves a certain distance from its original place, after it stops, the second object behind it moves the same way ... and so on to the last.
It is important that there is no randomness. So that the objects clearly follow one another, depending on their initial position - first the first along this axis, then the last.
It seems simple, but did not find such a script.
You can, of course, manually. but 200-300 objects ... hard ...
Thanks in advance.
Good luck to all!
Diffus3d
Hello @oprestonWK48B and welcome to the community,
I used to use radius for stuff like this, but I'm not sure it works on any version after 2018.  You might email Clovis Gay and see if he has any ideas at that link.
Best Regards,
