Announcements
SceneCleaner_Startup script "Struct Definition Handler Exception" issue 3ds Max
susy_s_aparicio
Observer Observer
susy_s_aparicio
Observer
Observer
Hi, I've downloaded the SceneCleaner_Startup script, pasted it to Scripts and Startup pastes and it doesn't work. This message showed when I've tried to run it. Is there any solution? Thank you
*Edited title for clarity
hagen.deloss
Hi @susy_s_aparicio ,
appreciate you coming to the forums with your question! Is it safe to assume you got the cleaner script from this support article? What issue are you trying to fix by running the script? Does the error happen on all scenes you run it on, or just a specific scene?
Warm regards,
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
