Scene Explorer - Selecting Objects Takes A Long Time
Anamorphic_DA
Anamorphic_DA
Hi, when I try to select objects in the Scene Explorer, it hangs max and is unresponsive for a long time until it comes back to life.
Does anyone have a solution for this? It seems to be slower for instanced objects.
N
Anamorphic_DA
I might have stumbled on the solution/workaround;
- in the Scene Explorer window at the bottom, there are presets in yellow. I changed this to "Layers" and it works properly.
raiden_xavier
Hi @Anamorphic_DA,
Thanks for sharing this with us.
From experience I usually encounter freezing or lag when the following conditions are met:
-Dense meshes (millions of polys)
-1000s of objects in the scene.
-Numerous objects have multiple modifiers on them.
-Non-optimal material setup.
-Outdated Plug-ins.
-Outdated or incompatible hardware.
You could quite likely select your post as the solution to this thread?
I hope you are well.
Anamorphic_DA
Thanks for that Raiden.
I've been using max since 2000 and therefore have alot of experience in maintaining my scene files but, the issue I was experiencing was not linked to any of the bottlenecks you mentioned. I think it's a bug in max TBH.
raiden_xavier
Hi @Anamorphic_DA,
Thanks for responding.
Always nice to hear from a user that has enough experience to avoid the basic potholes!
Autodesk have a few avenues available for support if you have a subscription and can clearly reproduce the issue.
Many thanks.
adv1LNQHZ
Observer
Observer
Hello there, I really agree with you on this. I am also using Max since 2000, I never experienced delay in selecting the objects from scene explorer even though the polygon counts are massive. I wonder, if it is not a bug what would be causing the delay in selecting the objects in the scene with my hi performance PC.
