I have the same problem. It's very stressful. Why is there is no solution to this thread?
Can you post a simplified model that shows the problem you are trying to solve?
I found the solution to this problem in another thread (that I cannot retrieve right now). Basically, in the top menu selecting customize, then preferences. In the opened window select animation tab, then check local center during animate. I don't know how to post a simplified model. Could you tell me how? Is it a screenshot? @leeminardi @Anonymous
To attach a file just drag and drop a .max (or .zip) file as noted below when you reply.
