Replace Autodesk Bitmap with OSL BitmapLookup when using Drag&Drop?
ACCCC
ACCCC
When i drag and drop a texture map into a material, f.e. PBR Metal/Rough shader it usually automatically loads them as a Autodesk Bitmap.
Is there a way to load them as a OSL:BitmapLookup instead?
Or maybe a scene converter script that converts Autodesk Bitmap to OSL:BitmapLookup?
@madsd?
madsd
Sure, Ill make a script and put in next version of Arnold Converter.
Legacy Bitmap to OSL Bitmap.
Ill put a note here later when its done.
ACCCC
That's awesome thank you.
I guess you'll upload it on your github aswell?
madsd
Sure, looking at it in 5 min.
Will post link here when working.
madsd
I had a look.
I already have the UBER OSL bitmap, the one with transforms in the converter.
https://github.com/gkmotu/ArnoldSceneConverterScripts3DSMAX/blob/master/Scene%20Converter/Conversion...
Let me know if this is working for you.
