render mp4 with audio?
I thought I had rendered mp4s from max with sound, but every attempt now lack audio. I do have sounds loaded in dope sheet and the sounds play in the viewport but no audio on rendered video.
thanks,
h g
Typically you render to image sequence, then use composting or editing software to combine video with sound and encode it. Exporting mp4 from max is a bad idea. Also I doubt it can export audio.
...thanks for the reply,
Yes, I almost always render frames and put together in Premiere, but I'm
making some short demos that render almost instantly and the .mp4s right
out of max look great. I just could have sworn I had rendered those
directly out of max with sound. I guess not. Thanks for taking the time
to answer.
