Randomly Rotate Objects
KraiggC
KraiggC
I feel like I'm gonna need to write a script for this, assuming there isn't one out there already for this. I'm trying to find out a way to randomly rotate objects I've place in a scene? Maybe even adjust scale slightly, but I can figure this out once I figure out the rotation part. For example, I place trees into parking medians and have them rotate randomly instead of going through and rotating them manually.
10DSpace
@KraiggC
For o in selection do o.rotation.z_rotation = random 0.0 360.0
Will rotate the selected objects on Z axis as you are describing.  If you want to confine the range of random rotation to less than a full 360 degrees make adjustments accordingly.
darawork
There is a script already for this, handily enough, here it is:
https://www.scriptspot.com/3ds-max/scripts/mass-randomizer
Functions:
  • Position
  • Rotation
  • Scale
  • Length-width-heigth- radius parameters
  • UV Offset Values
  • G-Buffer ID's
  • Selection (object and subobject)
  • Color and Materials "
    Has the ability to undo too, if I remember correctly.
    Pretty handy script, the additional extras in the drop-down are great.
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
KraiggC
Thanks Dara, exactly what I was looking for.. I guess my next question is how do I get it to permanently be in my 3ds, or do I just have to drag it in every time I want to use it?
Yes, I've done what was mentioned on the download link; but Tik wasn't under the category tab so I don't know how to add this script to any toolbar or quad menu.
darawork
I have a container script dialogue for all the random scripts I download. I don't make custom buttons, that fill up the toolbar. I have to edit them, just a few lines and it works. I'll explain in a new post this week coming up on here. Just not now. I typed out a massive explaination, to not opt for another button, or shortcut key. It was long and detailed (several full screen screen-shots embedded too. Video links too).
Then my account page log-on timed out. And I lost all that I had typed or screenshotted.
I suggest you checkout Scriptspot via Google. You can animate or automate anything with free scripts in 3dsMax. But each person might be less comfortable reading code, I say reading, but I mean scanning.
It's entirely doable. Even playing a MassFX game of Alien Invaders.
Less than a mb scene size.
There is a lot of code missing or not correct for anything past maybe 2018 Max.
Always save your main scene first, as a back up, with todays filename and version, at least once per 10mins.
Especially when random people try to type explainations to 3dsmax 2016-2023 online. And ask you to run strange  code. 🙂
Darawork
AutoDesk User
darawork
" but Tik wasn't under the category tab so I don't know how to add this script to any toolbar or quad menu."
I got a lot of HTML errors in the Maxscript. I fixed two, but it seems yer man has pulled it from scriptspot. Was too hard too download from Github and try to get it as normal Macorscript. The errors the 2018 version had are easily fixed. I just delete the lines of code from the ms wach time it gives a localised error. Or make something up.
https://www.youtube.com/watch?v=CFixg1t5UrM
Best of luck.
Darawork
AutoDesk User
10DSpace
@darawork  @KraiggC
I downloaded the script and found that the macroscript header info was commented out.  All you have to do is delete the enclosing " /* " and  " */ " in the first 6 lines of code in a text editor (or the maxscript Editor):
/*   <---delete
macroScript randomize
category: "Tik Works"
toolTip: "Mass Randomizer"
buttonText: "Mass Randomizer"
*/ <---delete
and then when you drag the edited Tik_Mass_Randomizer_v1.95.mcr into a viewport it will appear in the list of actions under "Tik Works" category as "Mass Randomizer:
Thanks, Dara for alerting me to this script.  Very useful.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
