[Question] UV No checker pattern on model
Hi, the UV checker pattern doesn't show up on my model, i have selected the checker pattern under the dropdown list in Uv editor.  However, if i made new sphere, the checker pattern does show up. Not sure what goes wrong.
Anyone please help?
Fadhil_Farook
You've turned on XRAY view for the object. Turn that off and it should be fine. Press alt + X or right click on object and go to Object Properties > General > Display Properties and turn off See-Through.
irishman_team_kilber
make sure you have show map enabled, it should be in the same place, but i am using an older version of max. image attached
