Quadrify question
This widget could not be displayed.
Quadrify question
Anyone know the script command for Quadrify selection? Not quadrify or quadrify mesh modifier. They seem to produce different results.
Quadrify selectin give me lower poly count then Quadrify mesh does event with the quad size % cranked way up.
thanks
raiden_xavier
Autodesk Support
Autodesk Support
Hello!
I noticed this post never got any replies.
Is this still an issue?
If it was resolved:
Please post what worked and choose 'Accept as solution'
If it wasn't resolved:
Perhaps I can help?
Having more solved posts makes a stronger community and helps future visitors.
Thanks!
actually it did not get resolved but this is what i'm using
I download Quadrify from scripspot and made a tool bar
macros.run "Modifier Stack" "Convert_to_Poly"
macros.run "PolyTools" "Quadrify"
raiden_xavier
Autodesk Support
Autodesk Support
Hi @Anonymous,
Sorry to hear it didn't get resolved, but thanks for updating the thread and helping anyone else that may run into this.
No problem at all. Its kind of tricky figuring out when your not getting a resolution and close the thread. One tends to leave it open in hopes to get a resolution after time goes on one (in this case I) forget lol
