AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
Quad menu viewport graphics issues.
strdr
Message 1 of 79
strdr
Hello!
Quad menu opens where is clicked in viewport, but on the left side of the screen/left monitor I get the viewport part behind the quad menu that was open, and it keeps stacking every time I open quad menu. It is happening on the windows/toolbars that are static.
Tried to downgrade, upgrade, uninstall, reinstall, different drivers, old ones, new ones, windows reinstalls, window updates, different accounts, one monitor, two, three, different graphics modes, run as admin, etc.,  like I have tried everything I could think of in past few days, but still no luck!
Fresh windows 11 install, 3ds max 2023, etc. This is the second time I did a format and new installs and the same thing is happening.
Chatted with support but they could not help, got opened a case but still waiting on that. Hopefully some one here has an idea what to try next?
Sharing a short video.
Thanks!
Replies (78)
Message 21 of 79
Diffus3d
If it's happening to multiple people (as it seems to be, I think it's a good idea to submit a support ticket over it.  Could be that it's a bug and it's just now showing itself, best to get a jump on reporting it.  If you don't mind, that is.  Listing your hardware might be a good idea, like motherboard, cpu, gpu, and windows/3dsmax versions.
There was a weird issue not too long ago that was only affecting owners of gigabyte motherboards, this may fall into the same category.  Thanks for taking the time to report it if you do.
Best Regards,
Message 22 of 79
strdr
I did make a ticket in the beginning, they could not help me so the case was open. still waiting on that.
Message 23 of 79
Diffus3d
Hopefully you can post this thread in the ticket too, then they can follow the steps so far.  Maybe list motherboard model too.
Best Regards,
Message 24 of 79
strdr
Good idea. Thanks for the help!
Message 25 of 79
eoboymurphy
Observer
Observer
Just posting my specs to assist troubleshooting.
Asus tuf b650-plus WiFi
Gigabyte 4070ti super
And Ryzen 7 7800x3D
I have tested 3ds max 2025, 2024, 2023.
Latest studio drivers and latest game drivers, also rolled back to previous driver versions.
Tried different display drivers within 3ds max too.
Message 26 of 79
strdr
Here are mine:
ASUS PRIME x399-A
TR 2990wx
128GB of RAM
3070Ti
I have send the thread in the email I have got from technical support where the case is open.
Message 27 of 79
strdr
To add an update to the bug, also when opening and closing layer explorer does the same thing. It is strange  because sometimes is doing it less sometimes more. Sometimes stays and sometimes disappears.
Message 28 of 79
Diffus3d
Interesting.  So you both have Asus motherboards, AMD cpus, and NVIDIA gpus.  Could be a clue for them.   I also have an amd cpu and NVIDIA gpu, but a different brand of motherboard.  (Asrock)   Note for support specialists: I do not have the problem.
Best Regards,
Message 29 of 79
Diffus3d
I wonder if there are any bios updates for your motherboards.  If you don't know what you're doing with those, they can be dangerous but might be worth a shot.  Please note that it's just a possible thing to check, I can't officially (or unofficially) suggest that is the fix.
Best Regards,
Message 30 of 79
eoboymurphy
Observer
Observer
Any news?
Message 31 of 79
strdr
Nope. They asked couple of questions on Wednesday and nothing since then.
Message 32 of 79
gianluca.canzini
Hi, I'm facing the same issue that @strdr was experiencing. I have a new pc with fresh windows 11 install, pc specs:
- Asus X870E Proart
- AMD 9950x
- Geforce 3090
@strdr did you perhaps find a way to fix this? It would be greatly appreciated if anybody has some tips, I honestly don't know how at the moment.
Thanks in advance
Message 33 of 79
Diffus3d
And now a 3rd ASUS motherboard.  I think you might want to check out any available bios updates.  So far, the ASUS motherboard is what you all have in common.  For what it's worth, there was a problem with Gigabyte motherboards earlier this year and they released a BIOS fix for it, as I understand it.
Best Regards,
Message 34 of 79
strdr
Hi. No solution yet.
Message 35 of 79
strdr
I have the latest BIOS update. As I mentioned in the beginning, everything was working fine, like for years, before the windows reinstall. Since the windows is pushing its newest updates while installing, I suspect something updated withing display settings in combination with 3ds max is making this issue.
Message 36 of 79
gianluca.canzini
 @strdr @Diffus3d  Thanks for the quick feedback, I really appreciate it.
Message 37 of 79
Diffus3d
It's a strange situation for sure.  This thread has some useful info in it, hopefully it helps whomever is investigating.
Best Regards,
Message 38 of 79
maxiaoju33
Observer
Observer
3d max is  good
Message 39 of 79
Kennet3design
Same problem for me. New computer, fresh win 11 installation, 24h2, 3DS max 2024.2.5
ASUS B650-CREATOR PROART D5
ASUS RTX 4090 TUF GAMING OC OG 24GB
AMD Ryzen 9 7950X Tray
Kingston Server Premium 128GB ECC 4800
Message 40 of 79
niklay82
Community Visitor
Community Visitor
It only happens when 3ds max is on the right monitor, so it shows the bug on the left. If 3ds max is on the left monitor it doesn't show it on the right. It's monitor refreshing problem that happens on the wrong monitor. Probably when using the quad menu 3ds max is asking windows on which monitor it is and after the last windows update it gets wrong/can't get an answer so by default is deciding that is on the left monitor so there refreshing happens - showing bits from the viewport with the size and the position of the quad menu.
