Proxy and xref differences and use for plants
Hello all!
A quick question about the differences between xref and proxy objects in 3ds Max 2018. I have done a fair amount of research, and find plenty of detail about mental ray proxy objects, and vray, but not much detailing what the appropriate solution is in 2018 as MR is no longer supported.
I am attempting to use a proxy object, or xref object if appropriate in a scene using the scene management tutorial provided by Autodesk in 2011 (https://www.youtube.com/watch?v=rk8oKYEuVFA) for grass. I have the grass assets modeled in a separate file and since MR is no longer supported can not find the appropriate method of saving a proxy/xref file. It would appear that the second part of the tutorial, regarding painting the sourced objects to my ground plane would remain the same if I simply find the correct method of saving and sourcing the files for this version of Max.
Thank you in advance for your assistance.
Matt
