problem with instance object
hojjat.naghash
Observer Observer
hojjat.naghash
Observer
Observer
hi to all
i have problem with instance object
when i use instance , material of objects that instance together doesn't link together and i change one of them doesn't change another
please guide me
thanks
10DSpace
@hojjat.naghash
By default, object Instances can have different materials assigned to them.  So while the objects themselves are instances, the materials are not instances.  But there is an option in the material editor "Propogate Materials to Instances".  If you check this first, then assigning a new material to one of the object instances will assign that new material to all other instances.
hojjat.naghash
Observer
Observer
hi dear friend
its work and solved my problem
thank you very much for your answer and time you spend
very proffesional
best wishes
