problem with importing fbx file into 3ds max 2018
Hello everyone,
I have a problem working now. When I import a fbx file into 3ds max 2018, the fbx file is not opened and cannot see like this image.
Unhide All or wireframe view is not the solution..
I cannot open any fbx files. (but, 3ds max files are opened)
Please help me~
CAMedeck
Instead of dragging and dropping the FBX, try doing File, Import, and select the file.  I've had issues with drag-n-drop a few times in the past.
Or, you can try Linking the FBX file to see if that is any different.
Chris Medeck
wow! Thank you so much !! I solved it!! 🙂
