Announcements
Problem with chamfer
eduardowp10
eduardowp10
Good afternoon,
I have a problem with the chamfer modifier, because when I use it, it deforms the object. It happens with all objects that use it.
I've attached an image of the problem.
What I wanted to do was a normal chamfer of the edges.
Thank you.
RobH2
It may have to do with the topology of the model and how you are using it. Can you upload that model so I can look at it?
Rob Holmes
3ds Max (2023-2025), V-Ray 6.2, Ryzen 9 3950-X Processor, DDR 4 128MB, Gigabyte Aorus X570 Master motherboard, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Space Pilot Pro, Windows 11 Pro x64, Tri-Monitor, Cintiq 13HD, Windows 11 x64
eduardowp10
yes, but it's not just happening to me with this object. It happens with everything I use Chamfer for.
RobH2
Something is wrong becasue the 'Chamfer' modifier has had a few upgrades lately and it's pretty sweet. Can you share that original model you showed? I'd like to have a look at it. Without something to inspect, I'm not sure how to help you. The Chamfer modifier works really well so if you are having issues, something else is wrong. We just need to figure out what. A model will help do that.
Rob Holmes
eduardowp10
here's the file.
RobH2
Which version of Max? It makes a difference because the last few years each release of Max has added new 'Chamfer' modifier improvements.
Rob Holmes
RobH2
I believe you were just using the 'Chamfer' modifer incorrectly. I sent a video and a new file you can open and look at. The file is Max 2025. If your Max is earlier, you can just open it and use the video to make the same adjustments. I hope this gets you going.
Rob Holmes
