problem with asset tracking
Message 1 of 21
I'm having problem with vault 3dsmax
I have a problem in the asset tracking because of the vault and so can not export my project with the material
could help me, look at the picture
Replies (20)
Message 2 of 21
Alfred.DeFlaminis
Hello @Anonymous,
I'd like to help you with your asset tracker problem.  It's not clear if you are intending to use vault or not here, so I have a couple questions for you.
1) Are you intending to use vault?  If so, you will need the path/server input here in order for it to function properly.  You may need to talk to your network admin or CG supe for the settings for the server.
2) How are you intending to export this?  To vault, or as something else?  Is the usage of vault unintended here?  What format are you trying to export?
Thanks for answering those questions for me and best regards,
Message 3 of 21
1- I thought that with the active account on vault in 3ds max materials and textures
would be recognized more by what I saw is not
2- I am trying to export my project in FBX or 3DS
but whenever I do it, it comes out without any texture or materials
even with the right mapping
Message 4 of 21
Alfred.DeFlaminis
Hello @Anonymous,
Are you able to log into the Vault server?  My assumption here is that your files are locked in the vault, and since you are not logged in, it is unable to access your textures.  Does that make sense?
Best Regards,
Message 5 of 21
tou trying, but I can not
I think I'm doing something wrong
always gives that business administrator
Message 6 of 21
Alfred.DeFlaminis
Hello @Anonymous,
Thank you for your reply.   I will try to help here.  You appear to be entering login credentials here, is there a reason why?  You seem to have a login for this... but no administrator?  Do you own this file?
I don't have 3ds Max 2009 installed, so I will list a few things you can try.
1)If you are not intending to use Autodesk Vault, maybe you could simply uninstall it.  Does Vault appear in your program files in control panel?
2) Do you see the textures in your viewport?  If so, can you open a blank 3ds Max file and File->Import->Merge the items in?
3) Last but not least, maybe you can try to do a resource collection?
Best Regards,
Message 7 of 21
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on your issue?
Best Regards,
Message 8 of 21
no avail
in my control panel in the event programs and resources
not in the client vault
will this be the problem? For some vault deleted files in Autodesk and still remained the error
Message 9 of 21
Alfred.DeFlaminis
Hello @Anonymous,
The vault is basically a version control and IP protection for assets.  If your assets are locked in the vault, someone did that intentionally.  Either your project manager or the owner of the IP decided to lock this into the vault.  It's not a big deal that you uninstalled Vault, you can reinstall it.  However, your files are locked in there and without the server name, they won't come out.
You have a username and password for the vault it seems, so it's weird that they didn't provide you with the server location so you can log in and check your files.  However, I don't think you will be able to get those textures without knowing the server name, or talking to the IT / project manager to be given access to those assets.
Best Regards,
Message 10 of 21
aff that tense
uninstall all residue from the PC and install autodesk 2014 version to see if this address
thank you for the patience ^^
Message 11 of 21
Alfred.DeFlaminis
Hello @Anonymous,
Best Regards,
Message 12 of 21
SAME THING
ONLY NOW THAT I installed the 2014 VERSION AND GAVE THE SAME RESULT
BEING NOW THAT HE ACKNOWLEDGES THE MATERIAL IN ASSET TRACK, BUT WHEN DO
EXPORT NOT GET THE MATERIAL
Message 13 of 21
Alfred.DeFlaminis
Hello @Anonymous,
Can I ask, where did you get this file?  If you want to PM me a link to it I can take a closer look.
Best Regards,
Message 14 of 21
if the program?
Message 15 of 21
Alfred.DeFlaminis
Hello @Anonymous,
I was just curious how the assets in the .max file you have were locked into the vault without your permission.  Is there anything you can tell me about the history of the file?
Best Regards,
Message 16 of 21
A YES, GOOD ITSELF THERE IS NOTHING WRONG WITH THE FILE, CHANGING OR REPLACING EVEN THE OTHER MAKES THE SAME RESULT
SEE A TEST THAT I MADE WITH ONLY 1 MATERIAL
ALREADY ALL mapped UV USER PATCH ADDED FOLDER FILE / MATERIAL
URL TEST VIDEO IN 3DS MAX
https://www.youtube.com/watch?v=lzThlzFHKKI&feature=youtu.be
Message 17 of 21
Alfred.DeFlaminis
Hello @Anonymous,
The FBX export doesn't automatically include your texture files.  If you check "Embed Media" when you export the exporter will create a subfolder with your textures in it.  Make sure you are using standard materials when you do so.
If this is the issue you've been describing since your first post, I don't think this is related to Vault at all and just a function of the exporter.  Please let me know if you have any questions.
Best Regards,
Message 18 of 21
thank you so much
with the diva you gave was essential on the ember Media
if I activated the media and ready ember.
Message 19 of 21
Alfred.DeFlaminis
Hello @Anonymous,
Is everything ok now?  Thanks so much for the update!
Best Regards,
Message 20 of 21
yes, it is now
Thank you for your help
