Pivot big problem, please help
Andre.GG
Message 1 of 13
Andre.GG
From the last few days i cant use 3dmax anymore, i dont know why
but the pivot now is blocked in one position ( in the pictures, you can see how now 3dmax drow the element )
After drow the element is impossible for me moved it or do any operation even in the curve editor.
please someone can help me (i try to reinstall the program and fix but nothing )
Replies (12)
Message 2 of 13
irishman_team_kilber
there is no photo you have not uploaded one, are you using the hierarchy panel to try and move the pivot point? do you have the padlock is the locked position is the pivot point on center on the main toolbar
If you reinstalled it then this should not be an issue, everything should be working. maybe you found a new bug.
Message 3 of 13
Andre.GG
i try everthings, i was in the pivot pannel and i dont know why my 3dmax use the working pivot but even if i deselect this option 3ds still use it
but the most strange things is that i cant move the box after made it, there is no look on.
another funny things is that i send the file to one my friend and she can use normaly the file
Message 4 of 13
have you tried to reset the max and do the samething to a new scene file and created a box and tried to move the pivot point that way if your friend has no problem with the file then you must of done something wrong,
do you have effect object only selected in the hierarchy panel when i locked this down i cannot use the pivot point when i unselect it then i can move the pivot point
Message 5 of 13
Andre.GG
there is no way that i can move the pivot in the center, when i try to move the pivot max move the object like that the pivot in the center is blocked there like that there is a constrain there. i i try to move the object and do the same things.
i try to reset max and reinstall it but is the same.
you know a way for reset the pivot but not with the normal way ?
Message 6 of 13
as i said in my last post if you have the effect object only selected in blue then you cannot move it when you deselect that option then you can move the pivot point you can use the center/centre to object this will reset the pivot point
  1. Select an object and then turn on Hierarchy panel Adjust Pivot rollout Affect Pivot Only. or you should just see reset option box
  2. Move or rotate the pivot. You can also use Align, Quick Align, and Align to View on the toolbar to align the pivot. See Adjust Transform Rollout for related information.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
Message 7 of 13
this site does not like me today try to load the image and it did not let me
Message 8 of 13
Andre.GG
I try from the start to reset it with the bottom but this not change nothing, the pivot is in the same position, im very sorry i can not show to you in the best way what is it the problem, i try to show you what you tell me in screenshot for show you that is not changing nothing.
Message 9 of 13
Andre.GG
Message 10 of 13
if you tried everything then i cannot help you anymore you have to wait until Alfred chimes in or someone else when they are online and knows more about the newier versions
Message 11 of 13
Andre.GG
thank you so much for try, i will wait them. tomorrow i have a delivery is a **** this problem
Message 12 of 13
Alfred.DeFlaminis
Hello @Andre.GG and welcome to the community,
In general, you don't have to reinstall Max if things start to get weird on you.  You usually just need to reset the user settings.  I've read through the posts here and looked at your screenshots, and this does seem odd.  When you create objects, are they rotated all weirdly like in your images?
Instead of using the Affect Object Only button, try the Affect Pivot Only button and then press "Center to Object".  Does that work?  Thanks for any extra information as I wrap my head around this.  I'm not sure I totally understand what is happening here but I'll do whatever I can to help you.  I suspect resetting the setting will help.  (Keep in mind that reinstalling doesn't reset the settings.)
Best Regards,
Message 13 of 13
Alfred.DeFlaminis
Hello @Andre.GG,
I just wanted to follow up here, any progress on this issue?
Best Regards,
