Path Deform Modifier Problem
Eznaex
Message 1 of 8
Eznaex
So the problem I have is that I need to keep my path deform modifier on, I still need to play around with it so I cant collapse. I want to edit some of the faces but whenever I choose a selection it removes it from the path, only the selected faces are on the right position.
Replies (7)
Message 2 of 8
irishman_team_kilber
mmm i'm not sure if you have the flip & the follow axis in the Path Deform blend but in the path deform then you can flip the control of the branch
Message 3 of 8
Eznaex
Sorry, I dont know what you mean?
Message 4 of 8
sorry i did not see the second photo it wasn't attached when i first looked at your thread i thought you just needed to flip the branch so it fits on the tree
Message 5 of 8
Eznaex
Thanks anyway.
Message 6 of 8
Alfred.DeFlaminis
Hello @Eznaex,
I made a video here with some alternate ideas for this issue.  There are many ways to solve this but I just showed 2 in this video below.  Please let me know if they don't help.  The 2nd one seemed useful based on your splines I see in your image, so I threw it in there just for the heck of it.  If you have any questions, just let me know.  There are some hard edits where I cut a bit to shorten the video.
Best Regards,
Message 7 of 8
Eznaex
This was a huge help! Thank you very much! I will definitely also try that second technique. Thanks again!
Message 8 of 8
Alfred.DeFlaminis
Hello @Eznaex,
Glad to hear it!  The WSM path deform can be tricky at first, I've had the same problem you were describing here a few times.  🙂  Have fun!
Best Regards,
