path deform assistance request
I am trying to make a helical path of pins configuration and I am having difficulty keeping the orientation of the pin perpendicular to the center of the drum.
Please take a look at these shots.
This is what i have now.   https://gyazo.com/1003878608aea4738778fd88444b330f
This is the orientation i want only still follow the path   https://gyazo.com/7a06fbbc87a89d00f11504e8872619a7
I have also tried follow path.
Alfred.DeFlaminis
Hello @Anonymous,
Nice job!  The helix does twist a bit as it goes vertically upwards, and I've had issues similar to yours in the past.  I think the solution for me was to use the array tool, and I made a quick little video to illustrate this in case it helps for next time.
Best Regards,
Thanks Alfred! Your second array method is what i used! But.... i forgot about using the 2nd axis! Wow sometimes it is so simple and staring me right in the face and i don't even see it. Thanks again
here is how it turned out in application.
https://gyazo.com/59fea916d46b904e2cbd7e321ce3df8a
https://gyazo.com/42de4a75e3a594cb8b6504bb9d335844
leeminardi
Here's another approach.  Use a link path constraint for positioning the pin along the helix but do not check the Follow box.  Instead, add an Expression controller to control the rotation of the pin about its X axis.
If the original orientation of the pin is 1.5708 (pi/2) then the expression is as shown below where F is the system variable for frame number, and nFrames is a local variable for the number of frames to complete the motion.  Of course this can be modified to adjust to the timing of the animation.
Lee
lee.minardi
Thanks Lee!
This is interesting. I have not worked at all with Expression controllers. I will have a look into it. Looks powerful!
Alfred.DeFlaminis
Hello @Anonymous,
That's looking great!  Thanks for sharing that, really cool.  I love how many options we have for 3D, so many cool ways to solve problems.
@leeminardi,
Very cool too!  That's a really fun and unique way to solve this issue.  Much appreciated for sharing that!
Best Regards,
